pro-kit problems
Take the vehicle back and make sure it gets taken care of. As I mentioned earlier, regardless of what OE style replacement spring is used (quality engineered, and not something sold from somebody's ancient caveman laboratory), that front suspension shouldn't look as if it has an "extreme canted thrust angle" if you brought it in with the OEM parts and appearing in good OEM condition.
That result is a result of an operator's technical error, not a manufacturer's.
I think most people including myself say that shocks don't affect ride height. I've changed out shocks and my car sits the same even with worn out shocks.
There is another problem... I wish I could help point you in the right direction or take a look at it.
A newb can do it in a day provided you have the necessary tools.
the driver side sits at 27" from the ground to the bottom center of the fender, the pass sits at 26.5"
