How Do I Go About This?
My mechanic checked the e-brake, wheel hub and axle and they were all fine. I was starting to wonder what the hell was causing this
Then I started searching through some threads on CZ28.com and came across this little nugget...
You said,...The sqealing occurs only under light braking or no braking...
Does a corner make it worse?
If so you have to shim the rear axle or the brake plates to move the caliper slightly. The caliper can rub on the disk and what you hear is a metal to metal squeal. There is a section in the GM shop manual about this.
The braking makes it stop because the force from the pads centers the caliper over the disk and nothing but the pads are rubbing.
If the noise seems to be from the rear axle, thats your problem.
Z28
Now I am fairly convinced that this is the answer to my problem
So my question is what would be the best way of approaching this?
Would I be better off just taking it to my GM mechanic and let a professional take care of it?
Has anyone else encountered this problem or a similar problem?
Any feedback on this would be greatly appreciated
Thanks alot
Chris
I swear, you guys sometimes over complicate things.
