Will a torque arm eliminate this?
I have been looking at this unit from Spohn
http://www.spohn.net/product.cfm?productid=1473
I just wanted to check with you guys and see if this is a common side affect of too much power on the stock setup.
Thanks!
If you still have the stock torque arm, you definetly need to upgrade it; the stock one is way too flimsy for serioius performance work. I recomend a TA that attaches in the stock location, though.
You might want to raise the rear a little before you got to the drag strip, but keep it low for corner carving.
Just another idea for you to check out.
The car is very low though – and has to deal with a ton of torque – so it could be either or both really.
Thanks!
Jeremy
Thanks!
Yes, its the torque arm. I replaced my stock one with the BMR adjustable (tranny mount). And the clunk went away...
Thats the torque arm that I got, the tranny mount. I am extremely happy with it. I really wanted the weld on one with the cross brace. But didn't want to deal with the clearance problems....
They are really all about the same - just asking.
I'm sure Spohn is a good arm also. I considered that one also, but decided against it since my car is lowered. You might do a search on how people like their Spohn arm.
Let me tell you, since you have headers, and since your car is lowered, you might have some clearance problems. That crossmember hangs mighty low. My car is a bit of an oddball, the suspension is stock, but yet the rear of my car is about an inch lower than any other Z28 I have seen, and yes I bought the car new so I am sure I got the stock suspension. Anyhow, with that being sad, if you get this crossmember mounted version.........
......you will run into some clearance issues with the street. They also offer that crossmember as a straight piece, but then it might hit your Y pipe, all depends on your setup. In my case, I might have been able to get away with the straight piece, but didn't want to chance it.
Also, if you order the Spohn one, order the bolts for the rear end as well, it's added insurance since the stock bolts are really too short and the nut only catches about 3/4 of the threads. With the Spohn bolts, you won't have those issues and more piece of mind.
Manny
