frint spring perch??
Old Sep 6, 2005 | 11:17 AM
mcowart's Avatar
Default frint spring perch??
I did my spring and shock swap..but i was wondering the front sits alot higher than the rear..could i do the hose mod in the front and take out that piece that the spring sits on...in the front
thanks
mike
Old Sep 6, 2005 | 01:42 PM
Cal's Avatar
Cal
Hmmm, never heard of anybody doing that. It could make the spring sit crooked and rub on the shock, but then again, maybe not. If you try it, report back here on the results. I wouldn't bother with the hose; the front springs are stiff enough to just pinch it right off.
Of course you could do it the right way and just order some coil overs from Ground Control.
Old Sep 11, 2005 | 02:22 AM
JasonWW's Avatar
Hose mod? Do you know the point of that?
No, don't take out the nylon spacer up front. Maybe you should consider raising the rear as the Eibach rears are known to sit low and be a bit soft. Here, check this thread, it's a common problem.
https://ls1tech.com/forums/suspension-brakes/323509-how-make-back-higher-after-lowering-car.html
