Anything to know before doing a spring swap,
By the way, the project is a 00 SS Convertible, just an fyi.
I guess I could ask also, is it necessary to undo the sway bar links, if so, why?
thanks again
This might help.
As for the rears, just pull the lower shock mounts loose (take the nuts off the back) with the chassis on jack stands and a jack under the differential, lower the axle slightly, pull out the springs, install new ones, jack up the axle and bolt the shocks back to the mounts.
A. Why mine worked.
B. Why the rest don't.
It's an elegant solution, if it only worked 99.9% of the time. I didn't originally realize that there was even a seal up there for that job, but that appears to be what the insert in the plate is for. If we could find a way to make that thing actually work, we'd be rich.....
for aditional help check out www.ls1howto.com they have instructions for front/rear swap
