Question about springs.
Old Sep 8, 2005 | 11:43 AM
old and good's Avatar
Default Question about springs.
are there any performance springs avalable that dont lower the vehicle?. the problem is that one spring in the LT1 f-bod that im working on is broken and needs replacement. and the rear end culd easaly handle being lowerd but the front end can not be lowerd any more than it is right now!
the problem is that there are many speed bumps in the place i live
also has anyone tried THESE springs they seem prety cool but how do they work? and do they lower the car?
here are pictures of the car to show you the fender gap
and this is a newer one
Old Sep 9, 2005 | 05:23 AM
Anyone?
Old Sep 9, 2005 | 07:43 AM
WS6WRX's Avatar
The link isn't working, so I'm not sure which springs you are talking about. The only "performance" spring I know of that won't lower the car are the GM 1LE springs. Have you thought about just getting another stock spring?
Old Sep 9, 2005 | 08:20 AM
YellowToy/A's Avatar
Ground control. They will let you pick the ride hight u want and you can pick the spring weight you want. They do not cost much more than just lowering springs. I paid 369$. You can adjust frount and rear. The stock shock is good for 300 lb/inch. If you get more spring rate you should get more shock.
Old Sep 9, 2005 | 09:30 AM
im sory about the link. its the drag lounch springs from eibach. does anyone know how much the stock springs cost?
Old Sep 10, 2005 | 10:54 AM
WS6WRX's Avatar
I have no idea if those springs lower the car or not, but I would guess they do. The rear springs on that set are probably really sofr and that little airbag is used to keep the rear end level during drag launches. I don't think they would be the best choice for a daily driver. You can look for some stock springs in the for sale section or Ebay. they usually go for really cheap. I think I sold mine for $25. The Ground Control setup is a good idea, but I don't think it's really worth it w/ out changing shocks as well.
Old Sep 10, 2005 | 02:30 PM
lowering springs cost about 200$ With ground control you can set your ride hight to what ever you want and you can get stock spring rate. 300 lb/in. The cost is 360$.
This is the only set up I cound find that was stock hight and the spring rate that I wanted.
Old Sep 10, 2005 | 09:34 PM
JasonWW's Avatar
Just thought I'd mention that GC fronts can be bought seperatly for $225. If you ever wanted to get stiffer springs, they run about $50ea.
If you still have the stock orange shocks they are not going to be able to control any kind of performance spring.
