front suspension
Old Sep 11, 2005 | 09:25 PM
stilsleepin's Avatar
Default front suspension
i have a 97 z28 and i have a bent k member that is getting replaced soon
so i tried a search already.
i want to put new bushings in the front control arms but i dont know which
ones to get. poly or the stock rubber
in the couple of months i want to lower the car
question is which bushings will 1. last longer
2. perform better
thanks
Old Sep 12, 2005 | 11:26 AM
00Z28SS's Avatar
Polyurethane bushings are by far better than the traditional rubber. You can never go wrong with them.
Old Sep 12, 2005 | 05:35 PM
Cal's Avatar
Cal
I have poly busings on the upper control arms, and they squeak like he11. Poly bushings in the caster position on the front lower control arms are known for having a short life span. I sugest you go with a quality oem replacement, like Moog.
Poly bushings will perform better if you are building a road racing car. Steel rod ends will perform best in that situation, though, but that requires new control arms. Moog black rubber will outlast them all.
Old Sep 13, 2005 | 10:18 AM
where can i find the moog replacements?
with the poly bushings is there a chance of bind?
Old Sep 13, 2005 | 04:31 PM
Red Orange 96's Avatar
Most autoparts stores should be able to get them, although they will probably need to order them. No shipping charges though, usually.
