anyone with this bilstein package
http://thunderracing.com/catalog/?ac...&vid=3&pcid=90 133-BTS-7501 Bilstein Suspension Kit, 1993-02 F-BodyIncludes 4 Matched Shocks and Springs. Lowers vehicle approximately 1 inch.
to me this looks sooo good, plus they offer a liftime warranty, any reviews on this package or comments on bilstein thanks
I personally have the non-slp eibach/bilstein combo. The handling is awesome but the ride took a good minute to get use to. It's a little rough for me. When it's time to get new shocks I will opt for the slp revalved bilstein shocks.
I just got some nitto drag radials and spohn lca's, so I am eager to hit the track again and see some improvements.
The shocks are the standard HD shock that is designed to work with the stock spring height and spring rate. These shocks have not been revalved and the ride is harsh and stiff with this kit because they just aren't matched up well with the spring operational parameters.
Most people return to the stock springs, have the shocks revalved, or remove the system altogether.
BTW-Koni has an excellet warrenty:
Q: What is theKONI warranty? How do I go about getting replacements?
A: The KONI warranty is a lifetime warranty to the original purchaser against defects in materials and workmanship and against wear out for as long as you own that car registered for street use. The warranty does not cover damage to the parts caused by misuse, misapplication, installation, motorsports, etc. The warranty does not include mounting bushings. If you determine you have a defective damper you can either contact the company which you purchased the unit(s) from or contact KONI North America directly at warranty@koni-na.com or 859-586-4100. To process your warranty, we will require a copy of the purchase receipt and a vehicle registration. We will generate a return goods authorization (RGA) and can replace the dampers in advance at your discretion. For more specific information about the warranty see inside back cover of our technical guide.
