LCA's are coming Monday soooo......
Is there going to be a noticeable gain from these beefier LCA's I got coming. I did my research and ordered UMI poly/rod ended ones and the grease for them. Any improvement in 60' times? Changes in everyday driving? I noticed a good gain with relocation brackets but will they be anything comparable to that? Any input on these would be appreciated so I know I bought a worthwhile mod before they're on the car. Thanks!
Originally Posted by CashMoney
if you suffer wheel hop you'll feel a diffrence
i had my BMR LCA's and SFC's put on at the same time and my car was a whole lot stiffer. However, i feel that had mainly to do with the SFC's. Like was said previously, if u have bad wheel hop, the LCA's should cure that problem. HTH
