? about panhard rod....
LS1TECH Sponsor
The Chome-Moly bars with those ends are $169.
If you just need the rod-ends, you'll have to call me so I can get you current pricing. Usually around $70/pair delivered without the adapter bushings.
__________________
Originally Posted by Pewter02TA
Where can these be purchased?
http://www.jonaadland.com/Z28/Mods/L...As.html#Update
Originally Posted by JasonWW
I just ordered a rod ended PHR from a little known company, to me at least. It uses a aluminum tube and uses the FK Bearing, model number JM12T. It's a JM series regular strength 3 piece in 3/4" with the PTFE teflon liner.
It's only $95 + shipping. Those rod ends aren't well know to most folks here, but they look pretty good spec wise and since the PHR isn't under a lot of load (time wise), they should last a good long time. When the time comes to replace them, I'll get some chromoly QA1 Edura 2000's which are well known, for about $30 a piece.
PM me if you want the details, they are not a sponsor.
I'm very impressed and I think the finish came out great. There were a few bad spots (use good masking tape), but I still think mine is the niciest looking PHR I've seen yet.
I put in the double rod end chrome moly phb from Sam Stanos. It was only 169.00. once you adjust the rear end into position its all good. Do a search on this forum for Sam's name and you can see what kind of businessman he is. good luck
