Front bar only or both?
Old Sep 20, 2005 | 09:31 AM
Adrian87GN's Avatar
Default Front bar only or both?
Just did my first real auto x last weekend and I see that the stock bars aren't up to the task. If I just get a front bar will I be kicking myself for not getting the rear at the same time? I planned on getting the Strano hollow 35 front bar, and his matching 22 rear (I think it's a 22) but I have no clue what difference the rear will make. Anyone care to give me some pointers?
Old Sep 20, 2005 | 10:44 AM
BitViper's Avatar
Ive had no real experience myself..but...from what Ive garnered from cruzing the boards the rear bar is "generally" sufficient but upgrading to at least the 1LE bar is considered a must do....
Having said that....Id prolly buy a front and rear install the front and have the rear just in case
Maybe Sam will chime in and pass along some pearls of wisdom
Old Sep 20, 2005 | 10:51 AM
BitViper's Avatar
As fate would have it.I juts found this..
Sam was giving advise in a diffrent thread..hope ya dont mind Lou..
If you opt 32 in front, stay 19mm in the back. Our bars are 35 front, 22mm rear, both hollow. The front bar is some 30% stiffer than a "1LE" bar, and 45% or so more than the bar you currently have. The rear bar is some 33% stiffer than the rear bar you currently have. The front of the car needs more bar increase than the rear does, the front has a camber curve that needs controlled, the rear does not. The front of the car carries the majority of the weight, the rear does not. The rear is a solid axle and too much rear bar stiffness vs. the front makes the rear jumpy and skatey.....
Full PostLS1Tech Post thread
Old Sep 20, 2005 | 11:14 AM
Sam Strano's Avatar
LS1TECH Sponsor
Lou was giving advise in a diffrent thread..hope ya dont mind Lou..
I'm Sam.... not Lou and that's my quote.
__________________
Old Sep 20, 2005 | 01:30 PM
Adrian87GN's Avatar
Thanks alot for that! Sam I think I will call you after lunch today and order your set.
Old Sep 20, 2005 | 11:00 PM
BitViper's Avatar
My applogies Sam....I ment to say Sam
Im an Idiot!
Edited my posts to reflect reality....I'll just sit down now and keep my trap shut
