welding in subframe connectors.
Old Sep 22, 2005 | 10:51 PM
half-n-half's Avatar
Default welding in subframe connectors.
hey guys when welding in subframes i know that the weight must still be applied the wheels, however i am a little unsure about a couple of things.
If i do it in my garage will i be able to weld them in with the front of the car jacked up and then placed on jackstands under the a-arms? or will i have to have the rear of the car also jacked up and place jack stands on the axle tubes?
Thanks
Louie
Old Sep 22, 2005 | 11:28 PM
joblo1978's Avatar
You could put the front on ramps and stands under the rear axle. Just make sure the car is level.
Old Sep 23, 2005 | 12:57 AM
ok that is the other thing that i thought.
what ramps are good to use? do you guys drive up on them or jack the car up and let it down on them.
Louie
Old Sep 23, 2005 | 07:46 AM
YellowToy/A's Avatar
I got two at Walmart for 29.00$ I alway jack the car up and set it on ramps. I am always think I am going to drive over them
Old Sep 27, 2005 | 11:52 PM
J&J Speed Shop's Avatar
Ramps, plus a high lift jack and plenty of 2x8's cut in pieces to get that bit of extra room so you don't bang your head or shiney new Miller stars and stripes helmet
Old Sep 27, 2005 | 11:54 PM
thanks guys. i am going to give it a shot later this week, my subframes arrive tomorrow, and i am going to buy a new welder tomorrow so i should be good to go.
Thanks
Louie
