SLP Linelock Install??
Thanks,
Bill
We also have a top mount kit for the LS1 that is MUCH easier to mount. The solenoid is placed (if you look at the picture listed above), near the grounding bolt located on the top fender area.
Having both styles gives the user options also...some folks mount their other components near the front location...the top mount kit certainly is the easiest mounting option.
618, nice clean engine bay you have there:-)
Bill
I have the solenoid installed with the lines. Which terminal on the solenoid is power (top or bottom)? The SLP writeup does not tell you. Since it is a switch I guess it should not matter.Thanks,
Bill
Now if my Earl's Line would of fit I would be set. Still have stock lines.
Thanks everyone.
Bill
I highly suggest the b001 kits as they are the best bang for the buck. They all work equally well and retain the same benifits...the difference in cost is solely due to the LL solenoid.
...SLP used to forward their customers to our vendors (they were available through vendors only, not direct at one time). Since then SLP decided to create a similar bare bones setup.
Differences in their kit: Their line lock solenoid is not re-buildable nor does it include some important safety features. Ours include additional circuitry theirs do not. This important additional benefit not found in an SLP kit lets the user know when the system is armed via an LED light and most importantly a MASTER arm switch which completely disables the circuit when not in use.
Without the master arm circuit, your line lock is always live and can be activated accidentally without knowledge. Worst of all, they do not use a momentary switch to activate the line lock. You COULD switch it on by accident when you’re cleaning your car or a passenger switch it unaware of what he did. This can have bad consequences…at minimum line locks shouldn’t be activated for more then ~60seconds, by doing so, can burn it out. At worst, an accident can evolve due to your brakes locking and staying locked when you don’t want them to.
The way our kit works is: when you know your going to use the line lock, switch the master circuit on, the LED will illuminate. Now the line lock is ready for operation at will. When you’re ready to stage, heat up your tires, the line lock solenoid can be activated by depressing the momentary button. When you’re done using the line lock, switch the master circuit off so the line lock is permanently deactivated. Accidental deployment cannot occur now.
Many folks whom have purchased an SLP kit realized this was an issue and added the additional circuitry necessary to include this feature. The additional cost of ~15-20.00 is not necessary with our kit as it includes everything
With our kits, everything is included. Picturial examples are given with directions, kits are always in stock ready to ship. We provide install guidance if the customer needs additional assistance.
Thanks everyone.
Bill
Bill
Bill
I need to install my Hurst line lock but it didn't come with a master arm switch.
Bill
