ADJUSTABLE oR NOT?
Old Sep 23, 2005 | 01:05 PM
joshs02ss's Avatar
Default ADJUSTABLE oR NOT?
I have 02SS M6 lowered with eibach pro-kit. I am going to be ordering bmr rear control arms, torque arm, panhard rod, hotchkis sway bars and strut tower brace,slp sub-frame connectors. Now my question is,i have been told i need relocations brackets for rear control arms, Why? what are the advantages of adjustable over non-adjustable? I want be car to be all around car hooks up tight on the strip, but rips through the corners for auto-x. if i had to pick i would going with handling. Thanks josh b
Old Sep 23, 2005 | 01:17 PM
Cal's Avatar
Cal
Anything adjustable is always better than not adjustable. For drag racing, front of LCA's should point slightly up; slighty down would be better for AX.
Old Sep 23, 2005 | 11:43 PM
joblo1978's Avatar
Get the brackets, you will notice a difference in traction, especially from a roll. I got the rod/poly LCA's from UMI. BMR does make a poly/rod end LCA. They are a good compromise between track/street and strip. The rod ends don't bind in the turns like poly/poly LCA's would but I still felt a gain in straight line acceleration. Not too squeaky or noisy, still a little clunky occasionally though. The rod end is also adjustable. Here's a link.
http://www.umiperformance.com/2016.aspx
BTW, these are good quality pieces and very beefy. Really planted my *** end good and feels great in turns. UMI also has great customer service from what I have seen.
