brake lines
Old Sep 26, 2005 | 01:45 PM
kyles2000z's Avatar
Default brake lines
aight i was taking my brake lines outta the lil box in the engine bay(idk what its called) so i could polish it up a bit. when i went to screw the lines back in the box, one of them wont screw into the hole. the first 3 screwed in fine, and the last one (back right) seems like it wont catch the thread to screw down into the box. all 4 lines came out easy. whats wrong here?
Old Sep 26, 2005 | 01:46 PM
kyles2000z's Avatar
i need help quick, gotta have the car driveable in 45 minutes.
Old Sep 26, 2005 | 02:13 PM
kyles2000z's Avatar
anyone out there......i gotta have my car in 20 minutes i need some help here
Old Sep 26, 2005 | 02:32 PM
scrmnws6's Avatar
Man, if it came out easy it should go back in easy. Make sure that the threads are alligned properly, push and turn. Other than that, someone esle is going to have to chime in to help.
Good luck.
Old Sep 26, 2005 | 02:45 PM
ROCNDAV's Avatar
Yup, what he said. Also, don't forget to bleed your lines, now that you disconnected the lines.
Old Sep 26, 2005 | 09:28 PM
kyles2000z's Avatar
problem solved now...i learned my lesson with brake lines
Old Sep 27, 2005 | 11:13 AM
ROCNDAV's Avatar
What was the problem? (THis could help the next guy searching in the archives).
Old Sep 27, 2005 | 12:12 PM
kyles2000z's Avatar
the system is air tight, kept forcing the screw back out. (i ended up having to bleed the brakes)
