line lock problems
Old Oct 5, 2005 | 10:54 PM
CrazCamaroz-28's Avatar
Default line lock problems
I Installed My hurst line lock and Bleed the brakes and the brakes work fine, but when I activate the lock I here a click and nothing happens the car will still roll and Ideas what I did wrong or if there is somthing wrong with the selenoid?
Old Oct 6, 2005 | 01:01 AM
Zeus's Avatar
don't mean to insult your intelligence, but I just want to make sure you're activating it correctly (you never know).
Anways, you have to hold the brake pedal down, then press the button while you're still holding the pedal down. You can't just push the button without having the brakes on.
The clicking noise means the solenoid should be opening and closing, so if you are activating it correctly, check to see if the brake lines are installed according to the instructions.
