Ground Control Coilovers
Now, I'll warn you of something here..... you get what you pay for. There are some sites selling for way under what they should be. You can go that way, and you'll likely get the product. Some folks have even taken the spring information I'm pretty free with and bought elsewhere. You can do that to. However, what you can't get for the street-corner sale price is the information to make it all work. Information about ride heights, alignments, shock adjustments (if you have them), what spring rates are best suited for your needs and dampers, as well as assorted other technical help.
I only tell you this as fair warning, because I cannot support product for free. You may not need or want my information and that's fine. But if you do, I really can't help you because I can't keep my business open giving away hard earned knowledge for free.
So how much is the rear setup then if it uses the stock spring location, i'm guessing you don't have to match it to certain shocks like you do the fronts?
My recommendation would be to get the shocks first (the Koni's work just fine with stock springs, and actually provide exceptional handling), then upgrade the springs when the money allows it. Doing it the other way around means driving a mismatched setup for some period of time.
Of course, as I mentioned it depends on what the rates are whether or not the shocks will work.
