LCA settings? need some input
Old Oct 31, 2005 | 08:23 PM
WS6FirebirdTA00's Avatar
Default LCA settings? need some input
so i just put my stock springs back in the car and will prob drop the car down again on thurs when i get the koni's in. now how should i set the LCA's up? there are the stock slots, and then 2 settings below that. i just wanna put them in the right spot, rear will be stock spring and possibly removed isolators. just dont know what kinda angle the lcas need to be at for best traction and what not. i dont have much of a clue if u couldnt have figured it out by now lol
Old Nov 1, 2005 | 10:08 AM
anyone?
Old Nov 1, 2005 | 10:54 AM
Cal's Avatar
Cal
It depends on what you are trying to do with the car. For normal driving around, it is best to have the LCA's level, or parallel with the road. For best traction in a drag race type application, the rear of the LCA should be slightly lower. For best handling on turns, road race application, the front end of the LCA should be slightly lower.
Old Nov 1, 2005 | 11:39 AM
ok thanks man
