Relocation Bracket question
Old Nov 2, 2005 | 11:34 AM
99SilverZ's Avatar
Default Relocation Bracket question
I bought a pair of Spohn weld-in relocation brackets. I've been hearing a few conflicts that using RLB's will put a lot of stress on a stock 10-bolt. I have also heard that RLB's will take the stress away from a stock 10-bolt. I also have Granatelli LCA's that the RLB's will mount to.
Which is correct??? Should I use them???
Old Nov 2, 2005 | 03:50 PM
Cal's Avatar
Cal
I suppose the added leverage with the longer brackets would put a twisting force or torque on the axle tubes greater than normal. The axle pushes the car forward by pushing on the LCA's. The torque arm would provide the "equal and opposite" torque to actually keep the axle from spinning. But until we hear of an axle actually being damaged this way, it would not seem like something to be concerned about to me. A lot of people use these brackets without incident.
Old Nov 3, 2005 | 02:02 PM
jorgez28's Avatar
I was think about getting these brackets to.
Old Nov 3, 2005 | 03:45 PM
napoleon's Avatar
pretty mucn any beefed up suspension part you add to our unibody cars is putting more stress on the rear end. There is alot of flex in the stock susp and taking that away allows more of the power you make to be put directly on the rear. There is no deflection...or at least, alot less. As far as why relocation brackets add more stress, i would have to think about it,
Old Nov 3, 2005 | 09:56 PM
99SilverZ's Avatar
So, I understand that installing the RLB's may cause more risk of my rearend to break. The reason why I'm asking is I installed aftermarket LCA's to eliminate wheel hop. Well, it decreased wheel hop but It's still pretty bad during hard accelleration.
Old Nov 4, 2005 | 08:00 PM
sikws6's Avatar
Sorry never heard of ANYONE breaking there rearend because of relocation brackets...
Old Nov 5, 2005 | 07:47 PM
rufretic's Avatar
If you think about it, any part you add for better traction is going to add stress on the rear. If you don't want to break your rear, don't add traction. If you want traction, plan on upgrading your rear.
Old Nov 5, 2005 | 10:57 PM
skatinjay27's Avatar
VERY NICELY SAID <STRAIGHT TO THE POINT .just go ahead and get them,i mean how offten have you seen or heard somone braek thier rear from them.
Old Nov 6, 2005 | 03:20 AM
Jimmy P's Avatar
I was about to say the same thing. These are designed to make you launch harder. When you launch harder with less tire spin, the rear end is taking more abuse. I got the Spohn brackets for the Moser 12 bolt.
Old Nov 6, 2005 | 05:42 PM
98boxer's Avatar
I just installed my relocation brackets -easy job- and I do feel it pulls better. It seems to get better traction on corners too.
I have a question though. I didn't drill a hole in the back of the part that I cut and just tightened the bolt. Doesn't seem it needs the rear bolt added, but should I add the bolt or will I be alright?
Old Nov 6, 2005 | 08:08 PM
JGA's Avatar
JGA
Hi
I have a pair of the Spohn relocation brackets that I have not yet installed. I thought I would save them until I lower my car, which may be a long time.
If I put them on now with stock ride hight, will using the lowest postion affect handling in a negative way? I suppose I can always use the middle position.
My car launches Ok for my type of driving, so do I need them on a non lowered car? Any input is appreciated.
Thanks JA
Old Nov 6, 2005 | 10:42 PM
98boxer's Avatar
Originally Posted by JGA
Hi
Thanks JA
I have stock height on my 98 z, and I used the lowest hole on the relocation bracket and it seems to effect the car in a positive way with more traction.
Old Nov 7, 2005 | 08:31 AM
jyeager's Avatar
This isn't necessarily true. What is true is that more traction means more force applied to the rear gears. But by more precisely locating the rear, you remove rear end windup which puts more stress on the rear end.
wheel hop will kill a rear end a lot faster than increased traction.
Controlling pinion climb is a function of the torque arm, not the LCAs. So a better torque arm is is possibly called for.
Old Nov 7, 2005 | 09:31 AM
rufretic's Avatar
Nice explanation. My post is not taking into account wheel hop. I've never had wheel hop and hope to never have it. Curing wheel hop should be 1st priority. Wheel hop is very bad for rear ends.
Old Nov 17, 2005 | 08:51 AM
99SilverZ's Avatar
Thanks for the info guys!
