Sway bar help.
I recently installed a spohn sway bar set and I have noticed a significant increase in squeaking noises. I know the kit comes with poly bushings, but are they supposed to be that annoying? I am also hearing a bang when going over bumps or up/down driveways since the sway bar install. The noise is coming from the front though. The bang does not always happen just sometimes...(randomly), sounds like something is hitting. I tightened all the hardware as good as I could. The front endlinks tightened down to where they couldn't be turned another turn, and the rear endlinks tightened till it looked like the bushings were begining to smash so I stoped there. I did grease the bushings before installing them to minimize the squeaking/noise. I did notice a huge difference in ride feel. The car is alot stiffer now, so I guess the squeaking could be from other parts perhaps. I guess I should add that the car is lowered if it matters. I hate to have to take the new sway bars out, but if I can't figure this one out they are history.
Need yall's thoughts and opinions on this one,thx.
