Wheel Hop?
Old Nov 11, 2005 | 03:26 AM
99blkt/a's Avatar
Default Wheel Hop?
So after switching to 18's w/ 295's I have a tendency of sever wheel hop occuring. I though this was just do to uneven pavement?? Sometimes it hops sometimes it doesn't, what exactly causes this, pinion angle?, and what steps can I take to eliminate this??
Old Nov 11, 2005 | 03:45 AM
musclehead's Avatar
A good aftermarket torque arm, along with lower control arms(lca's), and some lca relo brackets and you'll be good to go.
Old Nov 11, 2005 | 11:52 AM
Cal's Avatar
Cal
I agree with musclehead, but the most important of those three things is the TA. Same thing happened to my car with the Factory Z06 wheels and 295 Pilot Sports.
Old Nov 11, 2005 | 11:57 AM
ls1mongrel's Avatar
The lower profile tire made it worse on my buddies car when he put 18's on, he just got some umi lca,s , relocation brackets and a umi torque arm with the crossmemeber mount and he does get any more hop !
Old Nov 11, 2005 | 12:11 PM
Cal's Avatar
Cal
Yes, 18's are not good for these cars for several reasons. Seems to be a little known fact that I had to learn the hard way also.
Old Nov 11, 2005 | 02:18 PM
99blkt/a's Avatar
so is it the tire profile or pinion angle whats causing this......thanks for the advice was hoping it would just be some suspension mods
Old Nov 12, 2005 | 03:27 AM
glhs422's Avatar
Do you mind explaining what the reasons are?
Thanks!
Old Nov 14, 2005 | 05:23 PM
99blkt/a's Avatar
Yeah good point there what are the reasons
Old Nov 15, 2005 | 12:38 AM
Cal's Avatar
Cal
Well if you stay with something close to the stock tire height, around 25 inches, (25-18)/2 = 3.5 inches left over for sidewall height. That simply isn't enough sidewall on the back end of a rear wheel drive car to optimize traction. Especially such a car with a live axle. Not enough sidewall compliance. It hurts your launch in a drag race, and it makes it hard to put down power on corner exits in autoX and road race. On the street it makes the ride needlessly rougher. It adds weight to the tire/wheel combo which hurts in all applications. Even tires for them are more expensive. There is nothing good about them for our cars, except the bling factor.
