tranny and torque arm bushing question
Not trying to tell you what you want or anything, but I hated my poly trans bushing. And a lot of others don't care much for them either. Maybe you might see if you can get one used. Anyway, just thought i'd throw that out since you're new here. If you search for "poly trans" you should find plenty of info on them.
Originally Posted by curtisad
where can I get some poly bushings for the tranny bracket and torque arm?
Curtis
Curtis
You will diffently notice a differnce right away. Car feels a lot more solid with the poly bushings. BUT, heres a heads up, when you put the poly bushing on the tranny brack it will take a lot of muscle to close the bracket to install the bolts back on . This is the difficult part of this mod, closing the bracket with the poly bushing on. Good luck and you'll be happy you did this mod. Its just a struggle to get the dam bracket to close with the poly bushing, but no biggie.
