Eibach pros
Old Nov 14, 2005 | 12:44 AM
electricz28's Avatar
Default Eibach pros
What is the life expectancy of these springs? I think the rears are weakining. Whenever I hammer the loud pedal the rears sits down on the bumpstops or when speeds creep into the sound barrier. It also looks like the rear is sagging a bit. I have KYB 8 way adj. at all corners. What do ya'll think.
Old Nov 14, 2005 | 01:45 AM
Cal's Avatar
Cal
I think you should get rid of the KYB's and Eibach Pros. Replace them with Koni SA's and Eibach Race Springs, 500 lb/in front/150 lb/in rear. Your problem will be solved.
