Suspension Questions.
Old 11-22-2005, 08:57 AM
Bad Seller Warning!
96 LT-1's Avatar
Default Suspension Questions.
I just need some help understanding why having these sway bars and replacing the stock A arm kit and all this other stuff affects your speed so much?
i cant spend all this money on these suspension components if I dont know what it does.
Old 11-22-2005, 10:27 AM
LS1TECH Sponsor
Sam Strano's Avatar
I don't happen to feel that replacing a-arms effects you speed much at all. I do find bigger bars to be a HUGE gain to the handling and therefore the speed of the car.
VERY complicated to try and explain online. First I'd have to explain what each part does, and only then could I tell you why and when any part would be a benefit.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
