Shock/Spring combo
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
In a nutshell the koni's are the best shocks/struts for good performance both at the strip for traction and the street for handling.
Just remember there are many other suspension parts you will need to have optimum traction: torque arm, LCA's, larger sway bars, panhard rod, etc... Also as you may have already heard with a lowered car your going to need to get some lower control arm brackets and an adjustable panhard rod.
Best suspension mod I've done besides the Strano 35mm front and 22mm rear sway bars.
https://ls1tech.com/forums/showthrea...highlight=koni
However it's absolutely nuts to think that a Koni is any worse off with that amount of drop than any other shock is. Fact of the matter is they are designed for the car, including the range of motion the wheels go through. If you think that Koni didn't realize that some of these cars might not be lowered, you are crazy. And you should also consider the difference between wheel travel and shock travel. They aren't the same, a 2" ride height drop is not cutting 2" from the shock travel it's less than that (though I don't remember the ratio right now, I think it's about 1.7:1.
I'm really wondering where Yellow T/A gets some of his ideas.
And somewhere earlier I noticed that someone thought the ride height could be easily changed. It can, though doing all 4 corners will probably take an hour, and any change would require an alignment. In short, it's not something you'll be doing often or day to day (nor is that recommended).
Also, GC's are not an easy slip on install with Koni's. Not terribly hard to do it, but does take a hour or two extra work.
I have the GC's with rates I prefer and choose to run for autox use, and Koni's on my car. I'm also a bit more than 1" lower (more than the "perfect 3/4" drop for handling). I think my car handles ok... at least that's what my SCCA jackets indicate by the stiching that's on them.
FWIW.
Superman ^ that is what I would tell u to do with a 2" drop. Maybe Sam would tell what you should do. Koni and GC are more of an Autox setup.
