torque arm bolts
Old Dec 3, 2005 | 10:46 AM
sandro arellano's Avatar
Default torque arm bolts
does anyone know the specs on the torque arm bolts? i mean thread pattern, size and all that good stuff. i bought an edelbrock torque arm and those damn bolts keep coming loose, so im gonna try locking nuts. any help is appreciated....
Old Dec 3, 2005 | 12:50 PM
UMI Performance's Avatar
The stock bolts are 14mm but I forget the thread pitch with out looking, it is most likely the standard thread pitch a hardware store would carry.
Hope that helps,
Ryan
Old Dec 3, 2005 | 12:55 PM
what about the nuts.....arent they like 22mm or something.
Old Dec 3, 2005 | 03:33 PM
Wnts2Go10O's Avatar
Hope that helps,
Ryan
but remember unless they are grade 8 or better DO NOT use them. youll snap em like twigs.
Old Dec 3, 2005 | 03:43 PM
The outside of the nut might be, but you wanted the thread size correct? You buy bolts and nuts by the thread diameter and pitch, not the wrench diameter. The thread would be a 14mm and the metric grade that is equal to grade 8 is actually 10.9.
Hope that helps,
Ryan
Old Dec 3, 2005 | 05:10 PM
jimmyblue's Avatar
Moderator
They have a pretty high torque spec and if you
add Loctite to that, they should never back out.
That they are backing out, indicates a lot of
vibration; might want to check pinion angle. And
make sure you use a torque wrench so you know
you've done what's recommended.
Old Dec 4, 2005 | 01:32 AM
JGA's Avatar
JGA
Hi
If you are talking about the 2 long bolts at the differential, they are 9/16 course, grade 8 I believe. An over the counter length of 8 inch is just about right. You should also have 4 hardened steel washers and 2 self locking bolts. Nylon locks are good but the best is a jam nut. One end of the nut has a rim that is slightly oval and it jams on the thread.
The problem is most hardware supply stores do not stock 8" bolts, so they are very hard to find. Also, to order them over the internet from a supply company means a minimum $. You can get them from UMI, Spohn and BMR, but they charge quite a price. I got mine from Spohn and they work realy well. They were $20 US. If you can find them at a hardware store the price would be about $5.
JA
