Difference in spring rates of the QA1/HAL coilover springs
I have the 275lb springs up front on my QA1 Coilovers and they suck!! Constantly bottoms out on the shock and they are way to soft.. I have them adjusted about 85% of the way up the coilover and the front tires still rub when I turn and the car still sits REALLY low. So, I am going to swap them for the 300lb or 325lb springs. But, I just don't know which one to get. I have tubular upper and lower a-arms on the car right now and I am about to add my tubular kmember and manual steering setup also. The problem is that I am also adding a Iron block to this equation.. I want to keep the front end soft, but I don't want it to sit on the ground and bottom out on the shocks all the time. I guess I should go with the 325lb springs since I'm going with the Iron block.. Anybody have any experience with the 325lb rated springs??
What do you guys think??
