Body sway/ wiggle/ wobble/ living hell on the road...
Don't know the answer to those questions, but did you notice any clean spots around the bushings for the sway bar? That would indicate that the bar is sliding inside the bushings.
Originally Posted by Bowtie Guy
Did you check the torque arm? If the mount is broken where it connects to the trans....I would ger this car up on a rack and check everything!!!!!!!
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
well hopefully it helps, took mine to a shop and put it on a lift, the lca's wiggled a bit, and so did the pnhard bar, not to mention that my car is lowered and doesn't have an adj. panhard on it.
I hope this helps you all out, when ever I would get on the gas, my car would fell like the rear wanted to spin up front.....
