WS-6 & T/A sway bar ?
is their a difference between a 99 WS-6 front and rear sway bars and a "regular" 00 LS1 T/A front/rear sway bars? also would front spring rates or ride height be any different between the two?
thanx
thanx
Not exactly too sure, however the regular 99 T/A should have a 30mm/19mm combo, while the 00 WS6 possibly has a 32mm/19mm combo. Depending on options, the ride height should be the same, however here's a page, though the info could be seriously outdated:
http://www.ws6.com/faq/4_5.htm#ch4_5a
The WS6 has a 32mm bar, the Trans Am a 30mm bar. I know because I picked up a front sway bar of a 01 WS6 and measured it with a caliper before I installed it on my Z28.
