rear alignment/replace after collision
Old Dec 25, 2005 | 09:20 PM
Cumbias's Avatar
Default rear alignment/replace after collision
How much would it cost to replace the whole rear suspension after an impact that threw the driver side spring out if place and obiously messed up other components.
Old Dec 25, 2005 | 11:06 PM
Cumbias's Avatar
I should of clarified it more, replacing the suspension with stock factory brand new pieces. Is there a website I could check the prices
Korben's Avatar
Aftermarket components or stock? LCA's could be bent, PHR, Torque Arm, Shocks, Springs could be broken (most likely not) axles could very well be bent........
YOu could replace all of those stock components (buy used) for probably under 500 tops.
Aftermarket for most of it.......YOu can probably spend $1000 and get all nice stuff.
Old Dec 25, 2005 | 11:07 PM
Korben's Avatar
Lol, ok. Stock factory brand new.
gmpartsdirect.com is the website, I BELIEVE.
Old Dec 25, 2005 | 11:45 PM
Cumbias's Avatar
The website doesn't say how much the parts cost. Like Korben said LCA,Panhard rod, springs, brake lines (dripping fluid), and anything else that is nearby the components mentioned. How much it cost.
