2.5inch Drop?
I am not a fan of airbags or cutting the springs, I really hate everything about airbags and would never go there. Im going to do it with a good set of coilovers, possable GC with custom rate springs and then some revalved bilstons.
I think I should have said, How low can I go without destroying the cars handling but still being a lil lower than a 2 inch drop. Im thinking of going like 2.2 or somthing like that. And then at the track raise the car etc and around town or on weekends lower it or raise to what Ill need.
Changing ride height will throw off the aligment, although you can ignore all of that except the toe change. You will have to reset the toe, but it isn't that hard to do yourself. You really would not want to be jacking the ride height, caster, camber, and toe around for every racing event. But you might be able to do that twice a year, once at the begining of the racing season and once at the end. This is what I do. It will pay off to learn to do your own wheel alignments.
Thanks alot, yes Im only going to raise it and lower it only a few times if its needed. Great info you gave me
What is new or socially taboo due to lack of inexperience or knowledge is automatically concidered EVIL and not to be spoken of...whats the matter with a bagged suspension, REAL racers dont do those kind of things?.one guy thinks cutting springs is ok, another thinks FUN/necessity for the cause is to jack up the car, crank on collars, which regulary jam/ stiff turning...to try to accomplish the right load/ height, if not, jacks up AGAIN,(sound like fun yet?)when in doubt, ask....Air Ride Technologies web page.1/4, autocross, canyon running, bags immediate adjustment, might have to reach behind the wheel for a strut/ shock. dampning/rebound adjustment have installed for about 7/8 months now, had the bitch'n springs/revalves,yada yada,never got what i paid for. did my research, full air sus. with 12 way adj shocks/ struts, adj. pan bar..ect. NEVER GOING BACK. handles on rails....and can look good too. a dip, driveway, 1/2 set push on the controller, problem solved, then tap the button, all back...too easy....yeah, isnt that what everybody wants.full removed suspension pieces weighed against full replacing air system W/comp. and tank...around 10 lb., price worth paying for versatality and handling...priceless
What is new or socially taboo due to lack of inexperience or knowledge is automatically concidered EVIL and not to be spoken of...whats the matter with a bagged suspension, REAL racers dont do those kind of things?.one guy thinks cutting springs is ok, another thinks FUN/necessity for the cause is to jack up the car, crank on collars, which regulary jam/ stiff turning...to try to accomplish the right load/ height, if not, jacks up AGAIN,(sound like fun yet?)Coil overs are a bit of a pain to adjust up and down. You'll probably go through that once and decide it's not worth the hassles.
You say 12 way adjustable shocks. If they are Hal's or QA1's or similar, those generally don't have enough damping to really do the job in most applications. Actually, I can't think of a single adjustable shock for an f-body (besides Koni's) that is really properly valved for a handling application.
However, with that said, since he wants the car so low that any handling is going to go out the window, it probably won't matter what he uses and the air bags are probably as good as anything else (assuming they don't rupture and are durable).
