Torque Arm
Old Dec 26, 2005 | 02:24 PM
IVRedZ28LS1's Avatar
Default Torque Arm
Which should I buy? I got Pacesetter long tubes with a Custom built True duals X-pipe. I want one that will bolt on to a stock 10 bolt and uses the trans mount location on the side of it just like the stock one. Which one will hold? I don't want a TQ arm that is going to give me problems like breaking and all that other stuff you guys go thru. Thanks.
Please reply need the info on the torque arm. Thanks.
Old Dec 26, 2005 | 09:24 PM
Can Someone Help Me Please? Torque Arm Question?
Old Dec 26, 2005 | 10:24 PM
OldeSkool's Avatar
I really like UMI's
Old Dec 27, 2005 | 08:38 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Take your pick. There are many out there to choose from. I use Spohn's.
Old Dec 27, 2005 | 12:30 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
If you're gonna spend the $$ on a new torque arm then I would definitely go with a version that does NOT attach to the tranny tailshaft. This will save you from having to buy a second T/A later.
Once you start to make some healthy HP the tailshaft mount design put's undo stress on the tailshaft housing - and it WILL break - especially prone when on dyno.
You can either go with the Spohn which uses a slightly different front mounting configuration than stock, but uses a crossmember that bolts in place of your existing tunnel brace to get the mount point off your tranny - or you can go with a style that utilizes same sliding style of front mount as stock but has a seperate crossmember as well - such as the one from UMI or BMR...
Personally I went with the Spohn unit that also incorporates front & rear DS loops - I would have had no problem going with the other design but of course, they didn't come out till right after I bought the Spohn.
Old Dec 27, 2005 | 01:15 PM
noblesramair's Avatar
another vote for UMI, id get thier floor mounted version, makes a little more noise but if your looking for serious strength thats the way to go.
Old Dec 27, 2005 | 09:39 PM
Thanks guys for helping me out.
Old Dec 28, 2005 | 08:27 AM
bowtieforpower's Avatar
i have a bmr adj one and it works great. no complaints from me.
Old Dec 28, 2005 | 09:35 AM
slow96z's Avatar
Do not get the Edelbrock one, I broke 3 of them before getting the BMR. They took care of me on the broken ones, but it sucked having to change them over and over again.
