BMR springs?? Y/N
I just bought some and the research I did on them said they are good. I hear most lowering springs take away from the ride quality depending on the shock you use. I hear the BMR's work great with Koni SA's.
Originally Posted by bayer-z28
I've heard that these ride like crap
What do you consider crap? Some peoples perceptions are different.
I'm running Hal singles with BMR springs out back and really like it
I've heard that they ride like a rick-shaw, or a street carrage. One of the two.
Thatnx for the Imput, I really want to stay w/ all BMR components, (even replace my Hotchkis LCA's w/ BMR)
How would the function w/ stock shocks??
I had to put my stock shocks back on for a while and honestly it wasn't too bad. Depending on how many miles you have on your stockers I'm sure you could be ok. But with that being said the difference in the ride between a shock that is valved for spring rate is a big improvement. The difference is night and day and once you get good shocks you will never want to go back to stock shocks
-Patrick
If you're planning on running BMR springs with stock shocks then your car will ride like a "rick-shaw" or "log wagon" or whatever other concoction you can come up with
This also holds true for all lowering springs, Hotchkis, DMS, Eibach etc..
You need to properly match the springs with the appropriate shock, Bilstein revalves and Koni SA's would be your best bets.
So please, don't install lowering springs with stock shocks then come on board and complain that the springs suck. It's not the springs that suck, it's your shocks
Originally Posted by patricklee88
I will be getting some BMR lowering springs and I don't have the money for some shocks right now. Is it really bad if I run on stock shocks? I have about 43k miles on the car right now and I don't drive it too hard. Do you think I can get by with jsut stock shocks? Also what happens if my shocks are blown, is that necessarily bad for the car? Thanks guys.
-Patrick
-Patrick
They're still on my car, but I have some Strano revalved Bilsteins I will be installing.
The SLP Bilsteins are not ideal for the BMR springs, but they should be a significant upgrade from your stock shocks.
