Spohn Aftermarket Rear SB Mount Kit & Strano SB
I got a Spohn SB mounting kit for my Strange 12-bolt, on order, with 19mm bushings for my stock rear sway bar. If I order Sam's rear SB (I assume it comes with 22mm bushings), can I just substitute Sam's bushings for the ones in the Spohn kit and install his 22mm rear SB instead of the stocker (with the Spohn mounting kit of course)? Thanks.
To make this a little clearer, I mean use the Spohn mounting kit for aftermarket rears and just swap out the 19mm bushings that came with it and use Sam's bushings and SB (instead of the stock SB and 19mm bushings)? I can't see why not, but wanted to check before ordering the Strano rear SB. Anyone?
