help with qa1 installation
Old Jan 12, 2006 | 04:08 AM
2000zrocks's Avatar
Default help with qa1 installation
what do you do with the bump stop/dust cover? it doesnt fit inside the spring!
these are the 12 way coilovers. any help would be great. thanks
Old Jan 13, 2006 | 02:25 AM
2000zrocks's Avatar
never mind i figured it out
Old Jan 18, 2006 | 06:14 PM
Red95Formula's Avatar
did you use hal springs? I am trying to figure out how the lower part of the spring fits in the stock rubber seat? did you have to modify anything?
Thanks
Chad
Old Jan 19, 2006 | 05:58 AM
2000zrocks's Avatar
[QUOTE=Red95Formula]did you use hal springs? I am trying to figure out how the lower part of the spring fits in the stock rubber seat? did you have to modify anything?
Thanks
mine are coilovers with qa1 springs. so the bottom part sits on the adjuster nut of the strut.
Old Jan 19, 2006 | 06:12 AM
tillery's Avatar
yes, it should be spring, washer,adj. nut, and lock nut, and the top will go into top mount like stock.
Old Jan 19, 2006 | 03:13 PM
romoranger's Avatar
how did you get the dust cover to fit inside the hal spring?
Old Jan 19, 2006 | 05:50 PM
tillery's Avatar
did not use it
Old Jan 19, 2006 | 11:28 PM
romoranger's Avatar
yeah, i ended up just not using it either.
Old Jan 19, 2006 | 11:56 PM
2000zrocks's Avatar
i cut the dust cover off then seperated the rubber bumb stop from the metal part then put the rubber part on the strut. then i sliped the metal part between the coils then put it back together in the spring. i figure i should have the bump stop right?
