HELP! Still have really bad wheel hop
After installing a pair of weld in LCA relocators on my Moser 9", a new poly TA bushing, I still have violent wheel hop on the street or track. This totaly sucks! I cant get on the gas or my rear tires start jumping and the rear suspension slams into the bump stops. I also have Eibach pro springs on the rear, dont think they're hurting anything though. The only thing I can figure that's still causing my problem is the flimbsy pan hard bar that I custom made, it has metal ends and is very tight fitting but is too thin and when standing under the car on a lift I can push up or pull down on the PH bar and it will flex (made it out of 1/2" dia chromemoly tubing).
What LCAs do you have and where do you have them set up at? From what i have read up on hear i believe your supposed to have the LCAs set at the lowest level for the best possible traction. Im not sure just let someone with alittle more knowledge chime in.
-Joel
-Joel
-Joel
-Joel
Originally Posted by 98boxer
I think the panrod is giving you some problems. I belive with lowered cars you have to get an adjustable panrod to center the rear.
