controal arm bushings
front controal arm bushings where the a arm meets the body...the car is lowered and i think might be contributing toi this...i have replaced with a brand new one and it tore again...what do yall guys reccomend? is there a polyurithane fix or soemhtin
daniel
daniel
Lowering, using shorter springs, is tough on suspension parts. Did you only go an inch lower? Try a better shock if you haven't already; there are already lots of good recommendations on them here. My bet is: if you use a stronger, polygraphite bushing, something else will break. The right way to lower a car is to use quality offset spindles.
On another note, if English is your second language, you're doing better than I at my second, keep at it.
