ok guys what lowering springs are you running with longtubes?
I have a feeling that it will be time to change my shocks and bushings before too long in my Z, probably over the summer. The car has 95,000 miles on it and still has the factory shocks and such on it.
I would love to be able to lower it slightly. I do not want to slam it to the ground, but just enough to decrease that gap between the tire and the fender well.
I am also on a tight budget and I plan on one day putting a set of headers and y pipe on the car. (Not anytime real soon)
What would be the best set up for the money, including shocks and springs that will lower the car, probably around 1.5"? A website that would include images and prices would be greatly appreciated.
Thanks
-Bryan
Thanks
-Bryan
I've got ground control adjustable coilovers in front, and weight jacks in the rear. Never have to use a spring compressor again and I can alter the height at each corner. Grotyohann longtubes...boy, that's a word I don't see much any more.
The front springs are 10x2.5x650, and the rears are 8x5x300.
I have an Eibach Prokit, but still stock shocks on there
Would I see great improvement to something like revalved shocks? I just dont wanna rush into paying $500, and dont have the money to at the moment. I do scrape on some speed bumps no matter how slow i go
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
so if i was to get the eibach pro kit.....i would need relocation brackets? how much are these? i dont want to get new shocks just want to shorten the gap between the fender and tire.
Originally Posted by CODE4LS1
Eibach Sportlines w/Bilstiens at all 4 corners...running them with my SLP LT's, believe it or not no problems other than avoiding large speed bumps.
Do you have a catted Y-pipe???
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
I have longtubes waiting for install but using Ground Controls, check WS6store for the best price on those. I can get whatever drop I want, slam it, rake it, point the nose to the moon, whatever. They kick *** and I wish I bought them instead of the prokit originally. 450lb. front, 150lb. rear.
BTW, I recommend relocation brackets for any f-body with or without a drop. Even with the stock springs, I could feel a night and day difference in traction and the amount of wheelhop under hard acceleration and broken surfaces.
Good luck trying to reuse the stock shocks too, haha. You will most likely destroy the fronts getting the assembly apart. I know it's more cash to cough up, but if you're going to do it, do it once and do it right. At a minimum, have some new stock decarbons ready to throw on.
