Tramlining, Ideas?
A few weeks before I changed my setup from the standard 16"-5 Spokes and
245/50ZR16 all around to 17*9.5 wheels with 40mm offset and Hankook sport K104 tyres in the dimension 275/40ZR17 all around.
Everything fits perfectly and the car looks great, but now I have a very strong tramlining effect. At higher speeds (> 90-100mph, I'm living in germany), the car is'nt easy to control anymore.
I knew and expected that changing to wider tyres in the front, combined with the 40mm offset would bring some handling / tramlining... But I'm suprised how vehemently the car now snaps in...
Has anybody made the same experience? Do you think it's mainly a question of the type of tyres? I'm going to install Bilstein HD shocks, do think this will
help?
The car has still the stock shocks and springs, only LCA's and a PHB from UMI...
Any suggestions?
Thank you, Holger
Tires do make a difference as well. My car did it a lot with the stock Goodyear F1s, but then I switched to BFG KDWS tires and most of it went away.
I would have the alignment checked and make sure the tires are run at the proper pressures...other than that, it's sort of the nature of the beast.
