BAD ABS problem!
Old Feb 13, 2006 | 10:14 PM
RollinSScamaro's Avatar
Default BAD ABS problem!
Just wondering if anyone has had this problem.. during hard braking or when driving at a high speed and braking.. My driverside front wheel will engage ABS and no other wheels will..
it pretty much almost put me into a wall at the end of a track.. and i removed all of my ABS fuses and the problem went away..
Is it my abs sensor? or possible bad connection or something?
How do i go about changing the sensor itself if thats the problem? Thanks guys!
Old Feb 13, 2006 | 10:27 PM
SJM Manufacturing Inc's Avatar
ABS appears to be more a problem then it's worth. You can replace the components if you feel you need ABS OR you can delete ABS from your car. We do manufacture an ABS delete kit that will clean up your engine bay quite a bit while reducing ~15 lbs of dead weight.
You'll probably spend more money repairing your ABS system.
Good luck.
Old Feb 14, 2006 | 08:35 AM
hmm that may be worth considering.. its always just given me problems anyways.. and if you don't drive in the winter.. why would you have any use for it... good point! I'll check out that kit! Appreciate the idea!
Old Feb 14, 2006 | 08:49 AM
I've always stated, ABS is nice for a grocery car, but does not have any bearing on a drag car or road race car of which most people use the cars for.
Removing ABS will also lower the costs of a new Strange 12 bolt also and the hassle of re-using or purchasing relutor gears. In the end, you'll save ~100-200.00 from purchasing a new rear-end.
You will also not be limited to using the same tires sizes or having other ABS/TCS issues. It is also a great bang for the buck concerning a cost/weight expense! In the end, there really are only pluses to removing ABS...who can or would want to use a rear-wheel drive car with large tires in the winter anyways.
Good luck with your decisions,
Steve
Old Feb 14, 2006 | 09:11 AM
yea very good points! Thanks for the info.. as soon as some heat hits michgan i'll be ordering the ABS removal kit! Thanks
