ABS Delete Install problems
Old Feb 15, 2006 | 09:49 AM
LT99LS1's Avatar
Default ABS Delete Install problems
OK I bought a 9 inch rear and a abs delete line lock kit. I installed my 9 inch and my abs delete/link lock kit.
I had a abs inop light (expected),brake light (as you get if the e-brake handle is up and not expected) and a service vehicle light (not expected). I pulled the cluster and removed the abs inop light. Have I screwed something up for the brake light to come on?What can I do to make the brake light go out? Pull a fuse or relay? What about the service vehicle light?
I have the the porportioning valve set at 57% reduction on the rears and the rear brakes are still wanting to lock first about 50% of the time.
I have C5 rotors and calipers up front with earls braided lines and stock rotors and calipers in the rear with earls braided lines.
