1 inch diference between left and right side in the rear
The driver side sits 1 inch higher than the passenger side in the rear car is still in the shop they just got done doing the install on my 12 bolt. Could they installed the springs wrong or what.
If I remember correctly (been awhile since I looked) the tops of the rear spring perches are contoured to fit the spring a certain way. You have to "clock" the spring (spin it) in the perch so that the top ends of the coil sit in the pocket a certain way. Otherwise you'll get one side that sits higher.
Or maybe I'm smoking crack lol....
Good luck.
Mike
Good luck.
Mike
Good luck.
Mike
Good luck.
Mike
That was what i was thinking I am getting my car back mon if they did not fix that problem i will mess with springs myself.
Yes, spring orientation is important. However, my car was off like that from the factory--passenger side one inch lower than drivers side. I cut the stock springs to even everthing out (didn't want stiffer springs).
