Hotpart.com triangular subframe connectors....(too cheap?)
ive found them for 169 shipped....
Non sponsor contact info
Camaro- Flat Tube Subframe Connectors Triangular Style
F-BODY (camaro - firebird) - 1993-2002 Camaro / Firebird
A necessity for any performance minded builder.
Stops power robbing chassis flex.
Improves responsiveness & control.
Shaped to hug the floor pan of your vehicle for maximum ground clearance.
Doubles as a Jacking Rail.
Powder-coated to prevent corrosion.
Available for hardtop.
Weld-in only design is far superior and stronger than bolt-in styles.
Our SFC's are priced a bit more but the difference is noticeable in appearance and build. We have spent many hours designing our item to fit as tight as possible against the floor with out reducing ground clearance. If you look closely at out pictures will notice how each cross brace is actually bent to follow the floor contour rather then a straight shot reducing clearance.
Our main reason for building the 3-Point set-up was to work with our tunnel brace mounted torque arm. This helps to take the stress of the floor and spread it across the SFC's themselfs.
Hope that helps!
Ryan
Both are very nice set-ups. The boxed style is slightly more rigid but the tubular will take all the abuse you can put to them. The benefits of the tubular would be they are 4lbs. lighter and are offered in a bolt-in style as well if welding is not acessible. Either version will cause no ground clearance issues, the boxed style will hang below the pinch under the door approx. 3/8" while the tubulars tuck up very tight and can not be seen unless you actually bend over and look.
If I can help anymore please ask. Thanks!
Ryan
