Welding in LCA relocation brackets?
Old Mar 2, 2006 | 08:43 AM
mulletwearingtadrive's Avatar
Default Welding in LCA relocation brackets?
anyone have some instructions for welding in lower control arm relocation brackets....i have spohn lca's in already and need to weld in the brackets soon. thanks
Old Mar 2, 2006 | 11:29 AM
ifryrice's Avatar
Well its pretty straight foward on the directions. I welded mine onto my 12 bolt.
Old Mar 2, 2006 | 12:55 PM
i dont know where my directions are, think i lost em when i moved in january .....can you send me a copy or post instructions or something?
Old Mar 27, 2006 | 04:40 PM
obZidian's Avatar
is it absolutely necesary to weld in the brackets before running the car? Im considering installing them today and thought about running with them without being welded until the weekend...
can this be done or should i kick myself in the mouth for even thinkning this?
Old Mar 27, 2006 | 04:41 PM
OctaneZ28's Avatar
Seeing as they make bolt-in and weld-in relocation brackets, I wouldn't see the harm in just bolting them up for now.
However, I would definitely check with the manufacturer first before doing so.
Old Mar 27, 2006 | 04:50 PM
J&JsTA's Avatar
Here's BMRs instruction link http://www.bmrfabrication.com/instructions/cab001.htm
Old Mar 27, 2006 | 05:03 PM
obZidian's Avatar
i have a set of the spohn relocation brackets.... on their website it says that you have to weld them in for the best results but my questions is that the back part, when installed, will lock itself with the rear-end axles housing so it should be ok...
right?
Old Mar 27, 2006 | 06:12 PM
thanks guys but i already had em welded in
Old Mar 27, 2006 | 08:05 PM
smoknta's Avatar
There is a big difference between bolt-in and weld-in, the bolt-in have an extra tab that bolts the the shock mount. Without it they would swing back and forth.
