Need Some Help w/ Wilwoods
Just installed a 6-piston SL Wilwood front brake kit, however when I went to bleed the lines nothing was coming out of the valves.
Any one have any ideas, the fluid is making it to the valve going into the caliper however nothing was coming out on the top valves.
Yea, thats a good point. I was using an air suction bleeder for like 10 mins and nothing was coming out. Do you know the order to bleed? I know its the passenger side then driver, but what valve do you start with the outside one? Also do both valves on the caliper need to be open or only the one your bleeding, b/c there's two valves per caliper.
