PA Racing K member
PA Racing K member
Does anyone know what bolt sizes I need to attach this k member to the frame on my '95 formula. I know it does not use the stock bolts. I've searched around a little and have come up with two different sizes. m12 x 40 1.75 and m12 x 75 1.75. Just need to know which of these two are the correct size. Also, I need to know what size bolts to use to mount the motor mounts on this k member also.
Thanks,
Eric B
Thanks,
Eric B
um, I know I replaced them I forgot, what I used I know I took the originals to a hardware store and got longer ones, that could be a good starting point. as far as the mounts I used the originals, mine had the new mounting points only using the upper half of the 2 piece mounts though
