A quick bilstein question
Old Mar 14, 2006 | 07:44 PM
dyers98's Avatar
Default A quick bilstein question
Can I do just the rear for now? I'm kind of broke with home improvments. I found a good deal for a couple rear Bilstein HD's. Any harm in puting them on and doing the fronts a bit later?
Old Mar 14, 2006 | 07:47 PM
Foxxtron's Avatar
From the information provided, I would say it's okay, provided that:
1. They are new, not used.
2. If they are off the shelf HD's that will be used with stock springs.
Old Mar 14, 2006 | 09:51 PM
sills1's Avatar
Are you wanting to lower your car in the future? If so, do not do it now due to the fact that it will not only look weird lowered in the back, but the shocks will have to be reset for a lowering spring.
Old Mar 14, 2006 | 11:26 PM
DONAIMIAN's Avatar
Shocks will not change ride heigth, and when you get the shocks revalved its only the fronts.
Old Mar 15, 2006 | 10:01 AM
dyers98's Avatar
I am not lowering the car. I have SLP long tubes and SFC's. Not alot of room left under there. Shocks are new and stock springs will be used. Does that make a difference? I just want a better ride.
Old Mar 15, 2006 | 11:19 AM
Sam Strano's Avatar
LS1TECH Sponsor
They can change height (Koni's front perch that moves for instance, though Bilstein's don't have that).
And while I generally only revalve the fronts, the rears are NOT 4th gen HD's either.
__________________
Old Mar 15, 2006 | 01:13 PM
sills1's Avatar
Thanks Sam, I was just about to post a link to your site concerning that lowering issue with shocks only. Good to see ya looged on.
Old Mar 15, 2006 | 03:05 PM
dyers98's Avatar
So is this ok to do or should I wait?
Old Mar 15, 2006 | 04:58 PM
sills1's Avatar
Send Sam a PM and tell him the situation. He will probably be happy to give his opinion.
