help! problem after brake job
the pass side isnt as bad.
wtf is going on here? why are they doing this? is it possible the pads became contaminated during install? i thought my hands were pretty clean......
http://www.installuniversity.com/ins...ds_mwarren.htm
If so, did you do bed in to something like the manufacturer's suggestions:
http://www.tirerack.com/brakes/tech/....jsp?techid=85
Bear in mind that if you did the above correctly, you'd still might have to perform a simple rebuild, something around what this document suggests:
http://www.installuniversity.com/ins...er_rebuild.htm
EDIT: As usual, I advise to anyone to retrace your steps in order to discover what really is wrong before getting knee deep into something that wasn't really that necessary to being with, however it wouldn't hurt to do a rebuild after lots of mileage to possibly avoid much more serious consequences later.
Some other things to remember is frequently check your brake fluid, bleed it periodically, and replace it at least every 1 to 2 years (depending on driver habits). you might also try to bleed the system to see if there are any air bubbles trapped (though I highly doubt it). Also, properly torque the lug nuts down to 95-100lbs/ft. upon remounting the wheel and 25 to 50 miles afterwards, otherwise you'll get some serious pad knockback.
