SFC problems - Question?
Old Mar 19, 2006 | 06:50 PM
jinxedz's Avatar
Default SFC problems - Question?
Ill make this quick and to the point.
I installed a pair of BMR weld-in SFCs last summer 2 months before the car went into storage.
After the SFCs were installed, I noticed a lot of different creeks, squeeks, and an assortment of loud and unpleasant sounds coming from all over the car (especially the rear).
The guy who put them on raised the car using a regular lifts... it was not a drive on lift. The suspension was not loaded.
Im thinking all the sounds coming from my F-Bod are due to improper installation... the suspension needed to be loaded when they were wleded on, correct?
Anybody else experience anything similar to this or Im I just crazy?
Thanks,
Old Mar 19, 2006 | 07:53 PM
01 Red WS6's Avatar
Suspension should have been loaded when they SFCs were welded on. I would think that's whats causing the sounds you are hearing. The best thing to do would be to have them taken off and reinstalled correctly
Old Mar 19, 2006 | 08:50 PM
jinxedz's Avatar
Thats what I was thinking... take them off and have them done properly.
Thanks.
Old Mar 19, 2006 | 11:18 PM
Foxxtron's Avatar
Did you or anybody measure both the items to be installed and their respective mounting positions and to "dry fit" them twice first before doing any welding? These steps are extremely improtant in addition to loading the suspension. Even if it's a perfect fit in a rush, having to cut anything welded on of any sort in order to correct it will put you in a mental bind.
Old Mar 20, 2006 | 02:35 PM
jinxedz's Avatar
what do you mean?
Id imagine its gonna be a real pain in the *** removing them, but my my car should go back to 'normal' (how it was before the SFCs install) after I remove them, no?
Thanks
Old Mar 25, 2006 | 03:26 PM
SSoCal's Avatar
why would the suspension need to be loaded for sfc?
Old Mar 25, 2006 | 03:49 PM
peterlawl84's Avatar
the frame is under different stresses when it is loaded. yea id bet the sounds are coming from improper installation. mine are bolted on, so im not sure how hard it would be to removed welded ones, but the suspension does need to be loaded when you align them. good luck
Old Mar 25, 2006 | 10:26 PM
One Kool Cat's Avatar
Thanks,
The connectors definately shouldve been put on with the suspension loaded. One other thing to check before you go tearing them out it the bolt torque for the lower control arms. I believe its around 90 ft lbs, you may even have to go a little more. When mine were installed the first bump I hit it sounded like the rear end was going to fall out of the car So if those bolts arent tight its going to make ALOT of noise. The proper way to tighten them would be to put the car on a drive on lift or the ground if you have to (as level as possible), loosen the bolts a little bit, jounce the car up and down a few times so the suspension can settle, and then tourque them to 90 ft lbs. If it still makes noise you can tighten them a little more maybe 105-110, after that if it still makes noise something else is wrong . hope this helps
