Odd Squeak
Old Mar 19, 2006 | 10:32 PM
spazzyfry123's Avatar
Default Odd Squeak
I have a 1999 Camaro SS hardtop equipped with the T-56 tranny. Just recently (recently meaning about two days ago) the rear of my car began squeaking. I could understand something like this occuring with a high-mileage car, but my car is just under 13K. I am posting this in this section because I am pretty sure it is the rear suspension since it appears to make the squeak only when the suspension is being used (I'm aware that it is always being used, I mean when the suspension encounters more "extreme" use than riding over a nickel). I am still using the factory suspension (no SLP upgrades that I am aware of - no options sticker on passenger door - so whatever the SS's come with from SLP or Chevy). So it squeaks when I go over a speed bump, or just simply get out of the car. Does anyone have an idea of what could be causing this so prematurely?
Thanks in advance!
-Tyler
Old Mar 19, 2006 | 10:49 PM
FunkyTownFBody's Avatar
Can you describe the squeak a little more? Is it like a chirp, or something a little longer like a creaky squeak?
Old Mar 20, 2006 | 12:46 AM
May Spin's Avatar
Bushings may be worn or need regreasing. The swaybar bushings are generally the culprit.
Old Mar 20, 2006 | 02:36 PM
I'm sorry. It is more of a creaky kind of squeak.
Old Mar 20, 2006 | 02:37 PM
Thanks! I will definitely look into it
Old Mar 20, 2006 | 03:04 PM
TJSZ's Avatar
I have the same issue. I believe it to be my rear isolators on top of the springs.
Will know for sure once I get the new shocks in and perform the hose mod a.k.a. removing the isolators.
Old Mar 20, 2006 | 03:43 PM
The Guz's Avatar
Indeed check your sway bar bushings. I had a similar squeak going over speed bumps. I had my brother push down on the rear of my car and noticed it was the sway bar bushings. I used WD-40 and the squeak is gone.
Old Mar 20, 2006 | 05:18 PM
HandsomeBWouderful's Avatar
I a mouse-like squeak coming from the rear of my car. Turns out the jack handle on the jack was out of its holder. Its worth a look.
Old Mar 20, 2006 | 07:08 PM
bearcatpride's Avatar
My mechanic told me never to use WD-40 or any other spray lubricant on my bushings. He recommended using only synthetic grease
Just wanted to share the info with others
Old Mar 20, 2006 | 08:29 PM
Well it's been raining today and since this is my daily-driver, I had my first experience in the rain with the car. I am assuming that water from the road got to the bushings (or whatever it is that is making the squeak) and I didn't hear it once while going home. I guess the water "lubed" whatever the problem was? I will post more updates as the weather lets up some and I can have some dry runs to see if the squeaking persists.
Old Mar 21, 2006 | 10:07 AM
Get some white lithium grease from a parts store and use the straw to lube the bushings on the swaybar. That cured some squeaks on my car.
Old Mar 23, 2006 | 07:36 PM
Heh. More than just a little squeak now...
https://ls1tech.com/forums/showthrea...41#post4477541
